Addison Williams 0 Posted August 2, 2007 I have a 93 Corrado and just mounted a 95 jetta vr6 coil pack engine in it. What do i have to do to run the coil pack vr6 in a corrado that was previously distributor. Please help me out! Also, if you have any diagrams or pics of engine wiring let me know. Thanks! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 3, 2007 You need some of the wiring harness from the 95 engine (Cam sensor, coilpack loom etc) and the ECU. Might be easier to put your Dist' stuff on the 95 engine. Quote Share this post Link to post Share on other sites
Addison Williams 0 Posted August 3, 2007 I probably wasn't too clear... I have the 95 engine mounted in the 93 raddo that was a distributor previously. It has the distributor ecu in it, but mainly i want to know what difference in wiring there was or what i have to do to make the 95 engine work in the 93. thanks for your reply Quote Share this post Link to post Share on other sites
Addison Williams 0 Posted August 4, 2007 Does anybody have info on this or has nobody heard of this kind of swap before? If you have any info i'd appreciate it Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 6, 2007 Erm, what i said originally! If you don't have the ECU, MAF sensor and wiring harness from the 95 donor car, it ain't gonna work in 93 car I'm afraid. Sorry. Quote Share this post Link to post Share on other sites
