punker 0 Posted August 3, 2007 Hi i have a 2.0l 16v corrado which has a problem.... :( it's really hesitant up to full throttle. when you accelerate at anything less than full throttle its really lumpy and it seems as if it want to go but something is holding it back. i've checked the spark plugs, all the leads and electrical conectors, the distributor cap, the air filter and there all ok. not sure if the timing is correct as its been moved and i cant find a mark on the fly wheel to set it. can anyone help... thanks Quote Share this post Link to post Share on other sites
corrado vr6 0 Posted August 3, 2007 just goin on what happend to my valver when i had the exact same symptoms, it turned out after havin some work done at the garage the lamba sensor had come disconnected causing it to run rough and be a bit hesitant put yr foot down ....nothin then vrrrrmmm took it bck to the garage connected it back took them 2 mins and been fine since. Somthing to check anyhow, but im sure others will have some more suggestions, also try a search and read through some previous thread its been covered a few times, more answeres will be in there, hope this helps :) Quote Share this post Link to post Share on other sites
punker 0 Posted August 3, 2007 thanks :D i will have a search through the forum Quote Share this post Link to post Share on other sites
punker 0 Posted September 5, 2007 hi is the lambda probe easy to disconnect, is it near the cat or can i disconnect if from the other end?? thanks :D Quote Share this post Link to post Share on other sites
nocrap 0 Posted September 5, 2007 The connection, as in the plug, is too the back of the engine bay low down on the left side....... Quote Share this post Link to post Share on other sites
