corrado1.8t
20v t problems
Hi im new to the scene and ive got a 1.8t conversion in my previous 16v, the problem is when the thermostat is plugged in it wont rev past 5500rpm and runs rought intermitantly but if i take it out it runs fine any no the sollution? any ideas would be great cheers
Clear the codes, go for a drive without the problem, plug in Vag com, note down the codes. Clear them again, creat the problem go for a drive then read them again. Should give you an idea of whats the matter!
Failing that just disconnect the thermostat :lol:
