sim0n_parker 0 Posted August 7, 2007 the engine codes are diffrent rallye is 1h? and corrado is PB. can the block and head be used as normal and use all existing manifolds charger etc? as i can get hold of a rallye one to rebuild for fun ;) simon Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 8, 2007 Corrado engine's are PG, There are differances between engines but they do fit in either chassis. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted August 8, 2007 like you say simon the main difference is the blocks the 1h from the rallye is stronger mate use the rallye engine if you can also has the FMIC set up too but if you can get hold of one to rebuild yourself you might as well do it anyway then slap it in yours when done! sell the other one or break it for parts Quote Share this post Link to post Share on other sites
