falconer01
starting Problem (Help)
My 1991 16v corrado wont start ? I dont seem to have power to the coil . But strange thing imanaged to get her running but once i turned engine of the problem stated again . Could this be the ignition switch & also does this car have ECU. Thanks :( :o
You *don't* have power to the coil? Won't that perhaps be the problem then?
Could be the ignition switch or any number of things. Need a bit more info though.
Sorry for details i have a intermitant fault IE no power at times to coil , I have checked for loose relays etc all seem ok. If i leave the car for few hrs it will start & run ok. But once stopped wont run again. Also checked the ignition switch connector looks ok. All earth straps are ok.
Thanks for reply. :D Sorry for all the questions but is there a relay anywhere i could check.
