corradog60stage4 0 Posted August 23, 2007 As most of you know that the past few years I didn;t have time to play with my C. But during that time I was buying goodies for it and today while i was cleaning up the garage I spent a few hours on the engine I will be using. my C which motor? get rid of that crappy plastic windage tray thingy new oil pan sports windage tray don't know why they stop putting those steel windage trays. remember to torque the oil pump bolts 15 ft pounds my clutch setup lightened flywheel, XTD 6 puck sprung clutch and stage 4 XTD pressure plate clean all mating surfaces with brake cleaner. you don;t want to have oil there new bolts a la volkswagen torque these bolts 44 ft pounds and a 90 degree additional turn. although they come with threadlocking I added my own as well. my makeshift centering tool waiting for the brake cleaner to evaporate getting there next week will be to mate the tranny and pop on the head. Here is my old not sprung clutch setup that had before. I will put this on one of the motors. need new bolts got two metal head gasket made in germany VW OEM Elring solid front mount new headbolts poly mount new coolant flange, these guys always manage to break or leak. my seat belts finally dug out the rebuilt tranny from the corner of the garage. the header for the G60 my fogs and will put in 3200K HID in them mock up with the tranny in place personalized touch from the boys at TRAC racing my stage 4 charger 65mm pulley Bahn Brenner RSR outlet cheap belt that is not maintain could to $$$ expenses Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 stage 4 porting by KK oil passage lies within still searching for my titanium valve spring retainers and sport cam springs in this bundle of stuff. got my port and polished head some where?? next weekend it is time to dig that out with the modified intake as well. Once all this gets assembled i need a day or two to remove and replace the motor in my rado. today in the garage looking for my valve train parts I found two more clutch disk that I had. used one is a neuspeed one and the new one was a four puck sprung. I don;t think i will use the four puck since it maybe too extreme for me. I have some new rado door handles too that I need to replace. painted red stock flywheel not lightened goes on the other motor found my ported and polished matched head here is engine number 2 in progress i have installed the flywheel and ACT clutch kit. you can see that this flywheel is not lightened. finally found the sport valve springs, titanium retainers, BBM adjustable cam gear, BBM assymetrical camshaft, custom big intake manifold (jet coated) and alot of swaybars. LOL!!! now to change stock valve springs to HD ones and titanium valve retainers ghetto stylz borrowed the tool from canadian tire and it was not the proper one too. had to improvise with a socket the damn vw retainers and springs are recessed after looking for some important parts, this is what i did this afternoon. new tranny to engine bolts 21.00 in bolts tranny install release bearing lever and new bearing grease up that fixed pivot point i used what i had at home which was this moly grease grease them contact patches slap that lube Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 install lever first tehn after install bearing make sure it is clipped on torque these babies to 59 ft lbs passed these for a mock up here is what them belts looks like always keep a few handy this is today's progress and boy my back is aching. no rain so move the wheelchair out i need more space. another treasure i dug up still in its packing when shipped from CA. it was from last year and i finally get to open it. LOL!!! i didn't like the rust Oettinger wheel i got shiat everywehre i wonder where the motor is? LOL!!! my workbench LOL!!!! where did this come from? 020 My old differential so that means I got a Peloquin LSD. Time to work on the motor now. passed a razor blade over the mating surface. my cam caps. VW metal headggasket the rebuilt head covered up in sran wrap. new headbolts 9 refer to bentley) new lifters anyone know what kind of a cam this is? I remembered it was a BBM assymetrical. can anyone confirm? installing the cam caps (refer to bentley) add a touch of oil. make sure the cap number and offset are correct. no those are not condoms. LOL!!! they work on teh same principle as condoms do since i don;t want shiat to go in. ] just put on a cover to prevent dust going in. BBM adjustable cam gear valve cover seal usually inside is dirty overall another angle Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 two words WASH ME I need space. found another treasure that I bought two years ago. BIG INJECTORS I didn't want any fueling issues @ 18 psi going to clean up that fuel rail spare cover Here are some more goodies i found and looks like I need to buy a starter, slave cylinder, studs, and nuts... new timing belt jet coated custom audi 5000s turbo intake manifold. new coolant flange oli cooler setup unorthodox racing pulleys Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 went and bought my new slave cylinder at auto camping for 56.36. the old one was made of metal but the so called newer and improved version is plastic. installed will be picking up my starter and alternator tomorrow from DNS 2000. you would need to remove the brass bushing and replace it with a new one when putting in a rebuilt starter. new brass bushing installed rebuilt starter heavy duty diesel mount Audi TT rear pivot bushings and sleeves Audi TT front wishbone bushing injector seals thermostat housing valve cover seal after getting these media blasted I primed them for painting silver metallic supercharger bracket mounted enlarged TB Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 slowly but surely couldn't remove the front end because of one rusted bolt that got jammed into the metal sleeve. chisel at work prying with screwdriver alot of weight gets applied to the front crossmember so adequate support of the motor is needed front motor mount is finished rusted out bolt inside the sleeve attempt to drill out bolt motor will be easy to remove now with crossmember off. old G looks in pretty decent condition motor has coolant and oil leaks now the damn exhaust manifold bolts are giving me grief. i broke off 3 nuts, removed 4 nuts and one is rounded. the rounded nut is wasting my time today. here is my progress for today and just pulled out the motor. picked up new cap and rotor I'm replacing the front hydraulic mount with an aluminium solid mount. Since there is going to be an increase in power from stock the standard M8, and M10 bolts will be under heavy load. So I decided to DIY them a size bigger to M10 for the M8 and M12 for the M10 that are 35mm long. here are the rusted stock bolts and here are the 12.9 grade socket bolts and washers. front mount picked up a prothane engine mount insert for under 20 taxes included from RMR. very simple to install and has good results solid motor mount for 25.00 from Tony you just push these into the stock mount to fill in the voids. took out the stock manifold and cat. it was hard but just time consuming getting rid of the bolts that are rusted together. used a rotary tool with a cut off wheel. LOL!!! manifold removed cat is next and the nut holding the clamp was so rusted that i broke it off. custom exhaust will come later after get some more practice with the TIG. checking out the race header the stock manifold and cat weighs a ton and with the header will shed a good 25 lbs off the car. will need to buy a O2 sensor new thermostat housing with 160F thermostat. can you see the 160 inside driver's side diesel mount both motors side by side old charger stage 4 a la KK back to no space to work damn it., Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 last night was checking out the stock throttle body vs the one i will be using with the bigger intake. any difference? to compliment the lower temp thermostat you will need a lower thermoswitch these boxes arrived finally some more parts everytime i have to move out this stuff on to the driveway so i have room to work out goes the electric wheelchair installed rear motor mount sprayed g-lader support and rear engine bracket DIY upgraded hardware for solid mount. M12 and M10 @12.9 grade almost rust free cross member with stock mount removed stock mount upgraded billet mount installed installed the pulley tensioner dry to the touch I installed the engine bracket installed tranny brackets all bolts are torqued to specs wire loomed a few hoses got to repair butchered the O2 wires trying to figure where to put this?? Quote Share this post Link to post Share on other sites
Dec 1 Posted August 23, 2007 Wow!!....nice work!That's a pretty detailed photo diary of the work too! :lol: don't know how you manage to find anything in that garage though! :lol: Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted August 23, 2007 Very interesting,good luck with this. :) I thought my shed was bad with tools and car bits. 8) Quote Share this post Link to post Share on other sites
Yandards 0 Posted August 23, 2007 Loads of good pics, nice work. I suppose the question would be why do you need new blocks and one old one? ;) Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 Wow!!....nice work!That's a pretty detailed photo diary of the work too! :lol: don't know how you manage to find anything in that garage though! :lol: thanks and once i get most of the project done all the leftover parts will be posted here for sale. :D yeah it is about time to clean it out so i have more room to work on the corrado but you do with what you got. installation of crossmember had to enlarge hole for bracket slight problem trying to align the front solid mount loom to clean up the wires yeah i don;t know why snapfish changed the link codes??? here are some goodies that are still not installed yet extra set of lucas calipers front stainless brake lines extra front upper strut bar a la neuspeed. stainless sebring muffler 100% made in austria Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 23, 2007 most of the stock wires and harnesses is cleaned up. found the ic and tinkering with the euro lights you can see the oil cooler looks like i need to cut out half of the bumper support off to fit it my workbench LOL! coilovers are in and just need to adjust height with which wheels i choose to use. the FKs or the Oettingers? I got less than 1 foot of space around the rear of the rado before it hits my tool chest. I got about 2 feet width on the passenger side. finally the passenger rear is in there is not much room and too many parts that i need to sell. help me out and buy them parts so i have more room to work :beerchug: making a T fitting for my boost gauge. I will be tapping into one of the vaccum lines that ataches to the intake manifold. parts cost me less than 10 bucks teflon thread sealer for 25 cents you can;t go wrong two barbed fittings t fitting tube fitting voila all assembled Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 24, 2007 install the serpentine this was how the O2 wiring was being butchered from previous owner Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 24, 2007 O2 installation important not to get any on the probe. if you do it is garbage Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 24, 2007 The Volvo's 12 row oil cooler should be adequate to cool the oil but if you know me i like to drive my cars really hard so I went with a Brand new MOCAL 19 row oil cooler instead. Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 24, 2007 got some new plugs tried to look for some W5 but no one had them so went with stock W6 possibility of old skool sound system possibilty of three sets of wheels with new tires 15 inch bbs 17 inch Oettinger 17 inch FKs FK coilovers FK wheels and tires installed interior rear leather autometer gauge pods peace of mind with metal impeller water pump Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 24, 2007 new stage 5 chip arrived this morning installing the chip today Quote Share this post Link to post Share on other sites
CTWG60 0 Posted August 28, 2007 Good work man my head is spinning :turn-l: looking at all this stuff your doing. What's that rear engine mount your using and where did you get that intake manifold from? :) Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 28, 2007 Good work man my head is spinning :turn-l: looking at all this stuff your doing. What's that rear engine mount your using and where did you get that intake manifold from? :) Thanks buddy! The rear engine mount is a solid rubber mount for a GTI and it has the Prothane Polyurethane insert in it. As for the intake manifold it is from an Audi 5000S Turbo and one of the intake runners was cut off and modified for four and the throttle plate was cut and rewelded. Quote Share this post Link to post Share on other sites
CTWG60 0 Posted August 28, 2007 Thanks buddy! The rear engine mount is a solid rubber mount for a GTI and it has the Prothane Polyurethane insert in it. As for the intake manifold it is from an Audi 5000S Turbo and one of the intake runners was cut off and modified for four and the throttle plate was cut and rewelded. Right I see! So you can't buy these off the shelf, you have to make them yourself? Who made yours? Whats the advantage larger runners? Or is the fact that they have a straight longer run into the ports of the head? Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 28, 2007 Thanks buddy! The rear engine mount is a solid rubber mount for a GTI and it has the Prothane Polyurethane insert in it. As for the intake manifold it is from an Audi 5000S Turbo and one of the intake runners was cut off and modified for four and the throttle plate was cut and rewelded. Right I see! So you can't buy these off the shelf, you have to make them yourself? Who made yours? Whats the advantage larger runners? Or is the fact that they have a straight longer run into the ports of the head? Well you can buy an Audi 5000S turbo manifold but you will need to cut and weld it to make it work on the corrado. I cut it myself and had a friend of mines weld it before I got my TIG welder now and the ceramic coating was done by a company for me. The advantages of larger runners is 25-30% more straight air compared to the stock G-60 one hence increasing the output with the same amount of boost. check out the difference of stock G-60 vs Audi 5000S Turbo Quote Share this post Link to post Share on other sites
CTWG60 0 Posted August 28, 2007 You don't have a part no. for the origional audi manifold do you? We don't have 5000s Audis in the uk and I'm struggling to id which car/manifold I should be looking for!! Did it look like this origionally? Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted August 29, 2007 You don't have a part no. for the origional audi manifold do you? We don't have 5000s Audis in the uk and I'm struggling to id which car/manifold I should be looking for!! Did it look like this origionally? sorry i don;t have the part number of the intake in question. the audi 5000S turbo was 1986-88 or maybe called CS turbo but the one pictured does not look like the original one i had. the ports in your picture looks smaller and it did not have that runner diagonal of the intake runners. Quote Share this post Link to post Share on other sites
