easypops
merc clk seats....will they fit?
as above, a friend has a set of these taking up room and he says i can take them if they will fit in the c
so does anyone know if it is possible?
pic 1 taken from ebay
pic 2 the only one i have of the actual ones....just :lol:
I doubt they will drop into the car but anything will fit if you have the skill and the patience, and sometimes the money...
mmm....that might rule me out then :lol:
erm best bet, if you can might be to unbolt you seats and compare the subframes, if its an easy cut/bend/drill to allow the merc ones to fit in place then give it a go, if not i'd say take the merc frames off, measure the C's ones accurately and ask hopefully you have a friend or your friend knowes a friend ywhos a welder/fabricator and they should easily be able to make them fit into the same mountings.... thats just the fronts though, not sure about putting rear seats in as the C's just pop out :shock:
