Skimask
VR6 Timing Marks
Hi Folks,
Just to confirm the timing marks on a VR6.
The flywheel marks are: 0 | T - I gather its the vertical pipe mark that's TDC?
Also - I couldn't find a timing mark on the crankshaft pulley (serpentine belt end) - there is an alignment mark on the block, but not on the pulley, is this correct?
Cheers
  ziderapple said:
There should be a very small notch in the crank pulley.
Yes I know, but there isn't one there - and its at TDC according to the flywheel - if it is the mark between 0 and T.
