Neil L.
Oh, oh trouble.......
From early this morning the ABS warning light(dash) has stayed on all the time when the ignition is on! :(
This obviously shows there a fault - what do i need to check first before fearing the worst!
Corrado VR6 1994 "M".
Easiest thing is to get it scanned with VAGCOM, should point to the offending faulty item. Sadly not a great deal you can do without to trace the issue.
You can at least go round and check the resistance of the four wheel sensors to see if any are noticeably different. But yes, if you have access to it, the quickest way to figure out the problem is to scan the ECU.
