MK1Campaign 0 Posted September 20, 2007 My VR6 is loosing its power steering oil fairly quickly and the subframe under the steering rack is wet with oil. What is likely to be leaking? The rack itself or are there some pipes i could look at? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 21, 2007 Hi, you need to de-grease it and then look for the source... if it appears to be coming from the pipe unions then you can get new seals from VW (green O rings) Quote Share this post Link to post Share on other sites
boost monkey 0 Posted September 21, 2007 there is a serious amount of pipeage buddy. and they are £££ from the dealers :( any pics? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 24, 2007 If the steering is heavier in one direction than the other, definitely rack. Peel back the gaiters to confirm. Quote Share this post Link to post Share on other sites
