dirtytorque
removing the sump on a g60
You should be able to get it off without taking the gearbox off - I think you have to remove the power steering pump (or the bracket that holds it on - can't remember exactly what now) to get to a couple of them though.
Agreed.. also check there is not a torque head in the centre of the bolt too.. It looks tight but a short 1/4" 10mm socket and a extension bar allways works fine.
