g60kpj
PAS too light!?
Hi, i'd like some advice on my PAS. It is so light that it's dangerous! Could it be a valve stuck on the pump or something else? I have a PAS rack from a 1991 16v corrado, would this fit my 1991 G60?
Many thanks.
So good he posted it twice!
Might be the pump. It is supposed to keep the output pressure the same regardless of engine revs but if that mechanism breaks down it would produce overpressure at anything more than idle speed.
No i've checked the tyre pressures and they're all ok. It's when you turn the steering wheel a tiny fraction it feels as if it's on full lock!! Very scary when going around corners!! :shock:
