g60kpj 0 Posted September 26, 2007 Hi,i turn the key the fuels going through and the engine makes a clicking sound asthough it wants to start but nothing else happens apart from a buzzing noise coming from the fuse box? I've checked all the fuses and swopped the relays with my other g60 but still no luck? Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted September 26, 2007 Check the lead from the starter motor to the battery, mine was dodgy and wouldn't start the car. Otherwise check the usual suspect - Ignition switch (£12 from VW i think) and check all the earth leads are in good condition. Beavisjem Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 26, 2007 You need to look for 12V going down the red and black wire to the starter solenoid when the key is turned 12v = knackered starter solenoid 0v = Ignition switch, Alarm etc Quote Share this post Link to post Share on other sites
vw domo 0 Posted September 28, 2008 have the same problem on my valver mate, but only when its hot, will be interesting to see how you get on, sorry im not much help. Quote Share this post Link to post Share on other sites
g60kpj 0 Posted September 28, 2008 Cheers supercharged,i'll pop out too the garage and see what i can do! i'll let you know how i've got on! Quote Share this post Link to post Share on other sites
sparks 0 Posted September 29, 2008 sounds like ignition to me mate check dizzy/coil / coil earth /plugs /leads etc etc could also be a dodgey alarm system grounding the coil ? cheers stu... Quote Share this post Link to post Share on other sites
vw domo 0 Posted September 29, 2008 could also be a dodgey alarm system grounding the coil ? iv heard about this before, how does it manage to do that? Quote Share this post Link to post Share on other sites
Pondy_p 0 Posted November 16, 2008 I have this at the moment - what's has the solution generally been? I susect dodgy immobiliser as I've changed ignition switch - I have also changed the cable from positive to starter (ps will any 16mm2 cable do?) - aarrgh i hate electrics Quote Share this post Link to post Share on other sites
