gollfy
2.0 16V Temp guage not working
I have a 1992 2.0L 16V corrado and the temperature guage does not work, and Im running blind with only the oil temp as a guide.
I have checked the condition of the wires and they seems ok and they are all connected
Is there a simple way to check the temp guage without taking the dash clocks out?
I know there is 3 or 4 sender units and how do I check these?
Thanks all
Hello matey, the sender that you want to investigate is on the right side of the block and to the lower right of the water outlet....i think if you earth that contact the guage should rise (could be wrong on that one though).
You can buy them for only a couple of quid from http://www.vwspares.co.uk, you need the 'one pin black' one.
What colour wire has it got going to it? red/yellow by any chance?
Is this the wire that goes to the dash temp guage?
Thanks for your help 8)
