Thom 1 Posted October 10, 2007 Hey, Bought a Gunson Fault Code Reader from Halfords yesterday for the modest sum of £10, so thought I couldn't go far wrong, It said it was compatible with the 9A on the box but turns out it's intended for use with the old style 2x2 data plugs and doesn't give connections for the newer socket. I have found the pin-outs for the newer 16 pin connector on the net but can't find the ones for the old plugs anywhere (so I can determine the equivilent pin to connect the reader to, it's simply a 3 wire device with a flashing LED) Does anyone have this info? 8) Quote Share this post Link to post Share on other sites
