robster 0 Posted October 18, 2007 Ideas Please !!!!! Have G60 to begin with, When i out the foot down the front of the car lifts and starts to drift to the left side of the road :shock: (dodgy when over taking !!!) You can correct this by turing the steering more to the right but it could catch you out. Front engine mount OK Just passed NCT?DOE so bushings are fine and not too long in it All help appreciated :? Quote Share this post Link to post Share on other sites
dinkus 10 Posted October 18, 2007 Get it on a 4-wheel laser alignment rig as I'd guess something's awry with the suspension geometry. Most bodyshops will have/know where a good rig is and a full setup will probably cost you around £70. Make sure you check, or get them to check all of your tyre pressures before you start tho :) Quote Share this post Link to post Share on other sites
andydlc-g60 0 Posted October 31, 2007 my vote is that your trackings out, check your tyres for uneven wear over the tyre tread Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 31, 2007 Could also be a seized rear brake bias vale / calipers / handbrake etc... Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted November 1, 2007 Could also be a seized rear brake bias vale / calipers / handbrake etc... Yep, mine had the opposite problem, pulled to the left when braking. Turned out to be a dodgy rear O/S caliper... Quote Share this post Link to post Share on other sites
