akacheesy 0 Posted November 13, 2003 Has anyone fitted replacements? if so I could do with a bit of help, a) I heard that Golf Mk2 or Passat (dunno model / years) are similar / the same? b) Tips on fitting i.e. How do I get the wire off the old one & on to the new one? c) At the moment the airflow seems to be biased in favour of the drivers side, any solutions ideas? ta Chris Quote Share this post Link to post Share on other sites
slot 0 Posted November 13, 2003 The vents are cable controled you need to check them,theres two in total !! :) oh yes and one on the heat control, but thats not important ! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 13, 2003 slotmachine said: The vents are cable controled you need to check them,theres two in total !! :) 3 actually dude. 1 does the screen, one does the face/feet and the other does the hot/cold. Biased to what on the driver's side? Feet, face or screen? If it's only coming out of the driver's side, one of the plastic trunks behind the dash must have come off, assuming you've checked the vent flaps are open on the passenger side? If you take the heater panel apart, all will become clear. Kev Quote Share this post Link to post Share on other sites
Bolster 0 Posted November 13, 2003 This is the post you want ... http://corrado.atx-hosting.co.uk/viewto ... 7931#47931 (assuming it's the late model controls you have) Quote Share this post Link to post Share on other sites
akacheesy 0 Posted November 14, 2003 Biased toward the drivers side, windscreen when its turned to screen, not sure about the others cos I can only turn the direction between the windscreen and foot wells. Took the panel apart last night, now blower No 2 isn't working D'oh! Sounds more likely that the plastic trunk has come away, is that a dashboard off thing? One other question, how the feck do I disconnect the cables from the controls? Quote Share this post Link to post Share on other sites
