mistrydog
Removing steering wheel????
I am removing my steering wheel on a valver, i understand that i need to remove the bose aswell?? (It is not the stantard steering wheel) i am pretty clueless on this All help, tips, advice gratefully received. Cheers :D :) :)
Hello - if it's a MOMO type (most are) then you will need to remove the 6 allen head screws and then the horn button to get to the big 22 or 24mm num underneath...
Make sure you have the right size socket and start with a straight wheel - maybe mark the position with some tipexx as the shaft is splined for adjustment.
Lastly, if your refitting the MOMO wheel, you can get new allen bolts from Halfords (see the bike section - brake disc bolts) - I say this becuase they are crap metal and often round...
