Daduh 0 Posted November 16, 2007 hi so here it goes... my G60 starts fine and runs fine until it begins go get warmer (65-70 degrees), after that the engine starts to flood and the car stalls... but only when it gets to those temperatures... i think its electrical (ecu or something...) what do you think? and in my onboard computer the enviroment temperature is always minus 40 degrees! that has never happended before... thanks Quote Share this post Link to post Share on other sites
Yandards 0 Posted November 16, 2007 Temp displayed via the MFA has no input into ECU/engine running. I would check or change the blue temp sensor or if not have a look here for fault finding the injectors: linkage My post covers the procedure for checking correct voltage etc at injectors. Quote Share this post Link to post Share on other sites
