alfarac 0 Posted November 16, 2007 Hello, I am kind of new posting here, I wanted to see if somebody could help me on my issue. I have a 1990 G60 with ABS issues, started with the ABS light getting stuck and losing the ABS, then lost completely braking power as the pump or something with the master cylinder had issues. I have already fixed the pump and computer and have restored braking power, however, I chekced that the ABS sensors are not working and need replacing. However, I am not completely sure where to find specific sensors for the G60. I also found out some ABS sensors, a lot cheaper for the 1992-1994 Corrado, however I am not sure if those will work for my car. If somebody has experience with this issues, is there places where they offer these sensors? (preferably in the internet as I live in Costa Rica, but I can order them from the USA) Will sensors for the 1992-1994 model Corrados work on my G60??? Any help on this would be gladly appreciated...Thanks!! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 19, 2007 Are you sure it's the sensors?? Have you had a diagnostic readout?? Sounds like you may have water in the ABS ECU which is causing random codes to be thrown up... Quote Share this post Link to post Share on other sites
