ardandy 0 Posted November 19, 2007 Just VAG-COM'd the VR6 and it came up with the following; We checked the fault codes and then cleared them. Started the engine up and then ran VAG-COM again. This was all done within 10 mins so the engine never got up to temp. The faults listed here were identical to the faults listed before we started the engine, I've heard I need to run the engine for a while after clearing the codes but we didn't have time and these came up immediately. VAG-COM Version: Release 311.2-N Chassis Type: 50 - VW Corrado Scan: 01,02,03,08,15 Address 01 ------------------------------------------------------- Controller: 021 906 258 AG Component: MOTOR PMC 1 Coding: 0261203109 Shop #: 1267357531 5 Faults Found: 00522 - Engine Coolant Temperature Sensor (G62) 27-10 - Implausible Signal - Intermittent 00553 - Mass Air Flow Sensor (G70) 29-10 - Short to Ground - Intermittent 00537 - Lambda (Oxygen Sensor) Regulation 11-10 - Control Limit Not Reached - Intermittent 00533 - Idle Speed Regulation 09-10 - Adaptation Limit Surpassed - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 1H0 907 379 C Component: ABS/EDS TEVES 04 1 Fault Found: 00532 - Supply Voltage B+ 35-00 - - Skipping Address 15-Airbags End ------------------------------------------------------- Now even I can figure out that the MAF and Lambda need replacing (this is being goingon months so I've given up going down the cheapest route!) but I'm not sure what the Idle Speed Regulation fault is? My ISV valve was replaced a few months back albeit with a used one. Could it be something else? I've also just replaced the Blue ECU temp sensor so I'm wondering if the fault its coming up with there is related to one of the others? Any ideas guys? Cheers! (to dr_mat too! :) ) Quote Share this post Link to post Share on other sites
steve @ 0 Posted November 19, 2007 Blue temp sensor error was probably from the last sensor. you need to clear the fault run the car and test again to see if it still comes up 8) Quote Share this post Link to post Share on other sites
ardandy 0 Posted November 19, 2007 2nd line down. :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 19, 2007 Did you clear the codes and rescan after a basic settings and drive ?? Quote Share this post Link to post Share on other sites
ardandy 0 Posted November 19, 2007 We just cleared the codes and then started the car. A minute later we did another scan and the above came up straight away. Quote Share this post Link to post Share on other sites
steve @ 0 Posted November 19, 2007 2nd line down. :) I'll get me coat! :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 19, 2007 You changed the ECU relay?? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 19, 2007 The faults listed here were identical to the faults listed before we started the engine, I've heard I need to run the engine for a while after clearing the codes but we didn't have time and these came up immediately. You ought to turn the ignition off and back on again after clearing the codes otherwise it don't matter .. Quote Share this post Link to post Share on other sites
ardandy 0 Posted November 19, 2007 Ah! :? Will re-do the check and report back. I imagine that the lambda & MAF will need replacing as it's not running right at all and it would explain a few things! Quote Share this post Link to post Share on other sites
