john2k 0 Posted November 22, 2007 ok am i right in thinking the only diffrance between a VR ABV 2.9 and a AAA 2.8 block is the bore diameter.As im looking into overhauling the engine soon and want to get a 2.8 block bored out to a 2.9 .Does anyone know of a decent engine shop were i caould get this done.thanks Quote Share this post Link to post Share on other sites
corozin 0 Posted November 22, 2007 You could get your block bored out by Bildon Motorsports : http://www.bildon.com/ Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted November 23, 2007 Theyre in the States though. Who does it over here? Also, how much is it normally? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 23, 2007 Two choices for the AAA to get 2.9:- 1) Bore to 82mm, use stock VW 82mm Mahle pistons @ ~ £650+VAT + back order lead time. Gives you 2861cc 2) Bore to 82.5mm, use Mahle 82.5mm overbore pistons @ ~ £600+VAT + up to 6 week lead time, depending on stock levels. Gives you 2897cc Boring is on average £100-£150 per block, but a tiltable milling bed is a must. Not that many places can bore VR6 blocks. Stealth racing do 82.5mm over bores all the time.....at least 4 or 5 a month. Lots are being built at the moment, so there was a shortage of pistons last time I spoke to Stealth. Their rebuilt block price installed is £2300 IIRC. Quote Share this post Link to post Share on other sites
john2k 0 Posted November 24, 2007 I already have a set of new pistons rings and pins that i got off ebay there standard 2.9 pistons just need a AAA block.Got hold of stealth Friday and was qouated £200 inc vat for the reboar.Phoned my local engine shop in Reading and was told 240 + vat and tryed one in slough and was qouated £100-£120.Sounds too cheap to me but could be worth a look. Quote Share this post Link to post Share on other sites
