m3evo
Fitting new door mirror to polo
Hi, Help needed please, Need to fit new drivers door mirror to 2000 model polo all screws out etc but cant work out how to remove window winder handle, many thanks Dave
there is a plastic ring around the base of the handle and you slide it away from the winder knob and it moves about 20mm and then the whole handle slides off
Come and join either the Club Polo or UK Polo forums. There's loads of good info available!
Tried sliding the spacer away from the handle as you said, and still no joy? when you move the spacer do you pull the handle away from the door towards you? as in north to south? not side ways as in east to west? cheers Dave
Pull it in the direction of the winder on the opposite side. East to west.
does not that depend which way your car is facing :lol:
