quicky1980 0 Posted November 28, 2007 Im unsure if the fuel guage is working and I just wondered how I could check it. Been told that connecting the terminals at the sender end will allow the fuel guage to think its full and therefore rise on the display unit. But arent their three wires on the pump end, therefore which wires do I need to connect? I know hte easiest way would be to fill the fuel tank full of fuel but I cant get to a petrol station as the car isnt running at the momment Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 28, 2007 Looking at the pump end (under the black cap in the boot) there is a plug, take this off and locate the 2 pins with the smaller wires that go to the gauge (the other 2 are fatter as they are power) Now look at the corresponding pins at the pump side (sender assembly) and measure resistance across them Reading full to middle to empty you should get 35 Ohms - 90 Ohms - 285 Ohms If you don't get the above and want to see if the gauge works then maybe stick a 100 Ohm resistor into the plug (60W light bulb should be about right for this) Quote Share this post Link to post Share on other sites
quicky1980 0 Posted November 29, 2007 cheers, thats brilliant information. Will try it this weekend Quote Share this post Link to post Share on other sites
quicky1980 0 Posted December 1, 2007 I have four wires at the fuel pump end but they are all the same thickness. But I tried bridging them using a resistor and no change on the fuel guage so I think its something else. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 1, 2007 I'm sure they were smalled but the power wire will be red and the earth will be brown and i think these are the outer ones so it's the middle 2 you want... Maybe just the needles dropped off the gauge? Quote Share this post Link to post Share on other sites
