KipVR
3.2 PIN OUT configurations
Can anyone help me out here, I need to know the ECU pin out configurations for a 3.2 (R32/Audi), does anyone have accesss to the info or know where I can get it from? Cheers :lol:
Cheers John :D !!!!! Sorry for not getting back sooner but have been compiling it for some time, I doesn't look like one exists, but there is a wiring diagram for the ECU so I created one from that......took me hours but really helps later on. if anyone can add to the blanks or spots a mistake then please let me know...
1&2 brown/red Earth connection -2-, in engine compartment wiring harness and then plenum chamber
3 black/purple D173 Connection (87), in engine wiring harness
4 brown/white Lambda probe 2
5 White Lambda Probe
6 black/brown T4h/2 Lambda probe 2 after catalytic converter
7
8
9
10 blue T4h/3 Lambda probe 2 after catalytic converter
11 red T4h/4 Lambda probe 2 after catalytic converter
12 green Lambda probe 2
13 black Lambda probe 2
14 blue Lambda probe 2
15 red Lambda probe 2
16
17
18
19
20
21 black D51 Positive connection 1 (15), in engine compartment wiring harness
22 blue/green T10w/3 T6/2 Vacuum pump for brakes
23 black D173 2-pin connector, in left engine compartment
Connection 2 (87a), in engine compartment wiring harness
24
25
26 purple/green Air Mass Meter
27 green Air Mass Meter
28 blue/purple T10/5 10-pin connector, white, in connector protective housing, on left in plenum chamber
29 black Air Mass Meter
30
31
32
33 grey/blue T10h/6 T6b/5 Accelerator position sender -2-
34 brown/white T10w/1 T6b/6 Accelerator position sender -2-
35 White/blue T10h/5 T6b/4 Accelerator position sender
36 green/red T10h/4 T6b/3 Accelerator position sender
37 green/brown T10/9 Climatronic control unit
38 black/white T10e/3 Cruise control system switch
39 white/red T10w/4 Clutch pedal switch
40 blue/red T10/810-pin connector, orange, in connector protective housing, on left in plenum chamber
41 green/grey T10/710-pin connector, orange, in connector protective housing, on left in plenum chamber
42
43 green/white T10/1 -243
44 brown/yellow Secondary air inlet valve
45
46 grey/brown Secondary air pump relay, in protective housing on left in engine compartment (control number 100)
47
48
49
50
51 white Lambda Probe
52 green Lambda probe
53 red/purple Air Mass Meter
54 blue/white Connection (speed signal), in dash panel wiring harness
55 white/yellow Brake pedal switch
56 black/red T10e/4 - Connection (54), in dash panel wiring harness
57 red/yellow T10e/2 Cruise control system switch
58 orange/brown CAN T10/310-pin connector, white, in connector protective housing, on left in plenum chamber
59
60 orange/black CAN T10/2 10-pin connector, white, in connector protective housing, on left in plenum chamber
61
62 red/green D78 Positive connection 1 (30a), in engine compartment wiring harness
63 Green/Brown Post Cat Lambda
64 purple/red Activated charcoal filter system solenoid valve 1
65 white/purple T6/2 Fuel pump relay
66
67
68 Green/white Post Cat Lambda
69 Green/red Post Cat Lambda
70 Green Lambda Probe
71 black Lambda Probe
72 green/white T10h/2 T6b/1 Accelerator position sender -2-
73 Yellow/Green T10h/3 T6b/4 Accelerator position sender
74
75 blue/green T10e/1 Cruise control system switch
76 white T10e/9 Cruise control system switch
77
78
79
80
81
82 white engine speed sensor
83 purple/red Throttle valve drives angle sender 1, electric throttle t6/2
84 purple/yellow Throttle valve drives angle sender 2, electric throttle t6/4
85
86 purple/brown hall sender
87 blue/red hall sender 2
88 purple/blue Injector, cylinder 3
89 green/yellow Injector, cylinder 6
90 brown engine speed sensor
91 white Throttle valve module
92 purple/black Throttle valve drives angle sender 1, electric throttle t6/1
93 blue coolant temp sender
94 grey/green Ignition coil 3 with output stage
95 blue/yellow Ignition coil 6 with output stage
96 purple Injector, cylinder 1
97 purple/green Injector, cylinder 5
98 purple/red hall senders 1 and 2
99 black Knock sensor 1 & 2
100
101
102 purple/green Ignition coil 1 with output stage
103 blue/grey Ignition Coil 5 with output stage
105
106 red Knock sensor 1
107 green Knock sensor 2
108 brown/blue Earth connection (sender earth), in engine wiring harness
109
110 purple/yellow Ignition coil 2 with output stage
111 grey/red Ignition coil 4 with output stage
112 purple/green Injector, cylinder 2
113 purple/blue Injector, cylinder 4
114
115 blue/brown Inlet camshaft control valve 1
116
117 purple Throttle valve drive, electric throttle t6/3
118 purple/white Throttle valve drive, electric throttle t6/5
119
120 grey/ blue Exhaust camshaft control valve 1
121 brown/purple Variable intake manifold change-over valveR32 ECU PINOUT2.doc[/attachment:3vnv7mqa]
No problem. It's good to know you found the info you wanted. Noticed you're not to far away from me & Chazrad as well - presume you'll come out to play when we all meet up again next year?
John
Oh yes definately on for meeting up!! My car is oficially off the road for a while now until I've sorted every problem on it :? . I've had the car for many years now (2001) and I have never driven it without something on it that needs fixing. So for 2008 I've decided to do without a car until it is fully sorted. Fickle beasts Corrados.
