quicky1980 0 Posted January 2, 2008 I have a strange problem where, if the fogs are on it will cause the wipers to also operate. Anyone had this before or anyone got anyideas where the bad wiring may be? thanks Quote Share this post Link to post Share on other sites
mattkh 0 Posted January 4, 2008 Hi 2 questions What car is it? Which wiper function do the wipers adopt when it happens? Intermittent/normal/fast. Quote Share this post Link to post Share on other sites
Valerian 0 Posted January 4, 2008 I would imagine that the wires are shorting against each other where they hinge passing through to the hatchback. If that makes any sense to you. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 5, 2008 Hi 2 questions What car is it? Which wiper function do the wipers adopt when it happens? Intermittent/normal/fast. its on a corrado vr6, if i remember right the intermitant wipers come on, either that or its the slow wipe. Ill double check. I would imagine that the wires are shorting against each other where they hinge passing through to the hatchback. If that makes any sense to you. Will be looking at the wiring tomorrwo and will pay attention to looking in the boot hatch joint, to see if theres a short there. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted January 8, 2008 I havent had chance to check the wiring but I did find out the slow wiper function comes on, and not the intermitant if that helps? Quote Share this post Link to post Share on other sites
