dirtytorque
golf mark3 vag-com question
Sorry.
A thousand pardons this is not a corrado engine.Its for a golf. :oops:
Ok
It is a newly aquired car.
So I have the camshaft sensor out of spec intermittent fault,which is causing intermittent engine cut out.
I have changed the dizzy for a new one as apparently you can't get a hall sender on its own for my model.
2 litre 1997 mark3 golf(AGG engine.)
It sill telling me that the signal is out of spec.
Thus i wish to check timing.
You get these options in Vag-Com under basic settings 07(For the hall sender)
7,0,Hall Sender DataADY, AGG, AKR
7,1,Hall - Engine Senders,57...60 or 1.0
7,2,Hall - Engine Senders,5...8
7,3,Altitude Correction,0.85 ... 1.15
7,4,Operating Cond.,Throttle 00000000
7,1 iHall Engine Senders is 12 on mine.
Should it be between 57 and 60 then ?
Anyone with any experience with this sort of thing????
ta
