moore1 0 Posted January 5, 2008 any help will be great. the electric window works on the passengers side but not the drivers side.when i press the electric switch all i hear is a clicking noise from the rear drivers side door card. very confusing. any clues. corrado k reg 16v thanks Quote Share this post Link to post Share on other sites
Phil K 0 Posted January 5, 2008 Think thats the window control module you can hear behind the rear drivers side panel.. Could be a dead motor? Only realy way to find out will be to get the door card off and rig a 12v feed direct to the motor then work from there :? Quote Share this post Link to post Share on other sites
Blaklabel313 0 Posted January 9, 2008 thats right, its the control module clicking, your window is either stuck...or you need a new motor/mechanism...mines broken too but if you want a new one they are £185 from VW. try for a second hand one but as the motor is held in with rivits you have to drill them out and fit the new one with some bolts...its quite fidly to be honest (cheers vw)..lol Quote Share this post Link to post Share on other sites
timg60 0 Posted January 9, 2008 Yup second that. I had the same problem. Luckily had a spare door with motor intact. Still took about 2 1/2 hours cursing and swearing.............. :lol: Quote Share this post Link to post Share on other sites
krnau 0 Posted September 30, 2010 moore1 said: any help will be great. the electric window works on the passengers side but not the drivers side.when i press the electric switch all i hear is a clicking noise from the rear drivers side door card. very confusing. any clues. corrado k reg 16v thanks was it ever fixed? Quote Share this post Link to post Share on other sites
