LukeManic
slave cylinder location
Hi guys, am I right in thinking the slave cylinder on a vr6 is located on the right hand side of the engine as your looking at it with the bonnet open? Im pretty sure I've spotted it but it seems to be attached to a large metal plate which isn't showing the two mounting bolts of the slave cylinder, does this make sense? Cheers!
hey there my friend if you check out the picture in the link below of the refurb i did on my car you can clearly see the slave cylinder (the shiny silver thing!) on top of the gearbox right next to the gear change mechanism thingy where the cables attach onto the box...
download/file.php?id=49042&mode=view
hope that helps
