corrado_sunderland 0 Posted January 17, 2008 ive bin looking at a set of FK 15mm adapters to make me g60 5x100pcd would these work ok and would i require the arches rolling etc for 17 or 16" wheels with this set up , also do ppl rate theses spacers as ive always stayed clear of spacers regards mick Quote Share this post Link to post Share on other sites
tandino 0 Posted January 19, 2008 Personally im pretty sure your going to get bolt overlap with 5/100? I think one bolt goes into the rim straight through the adapter and into the hub, The other bolts bolt from the new adapter to the hub? I guess id rather convert to 5/100 but if they are TUV approved? then they should be ok. Ive used H&R 5/130 to 4/100 before on my 20vt Mk2 and tracked it numerous times and been round the Ring with no problems Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted January 19, 2008 i gunna get the wheels machined to get the offeset rite and the spacers come in whatever pcd u want me friends has a set of 911 wheels 17" i gunna put on but i just unsure it 17" wheels wit fit a rado fine with no rubbing etc regards mick Quote Share this post Link to post Share on other sites
