timmaaah
Knackered MAF-can you help?
Hi all - poorly vr6 - been getting shocking mpg recently - like 17mpg if I'm really careful :shock: . Also, when you take your foot off the gas, the engine tries to stall, then hunts up and down for a minute or two.
After searching on this fine site I think it's probably the maf. I tried umplugging the maf whilst the engine was running and it made no difference, ie the engine revs stayed the same.
Can anbody near me (Reepham/Norwich) let me try their maf before I shell out £216.53 with VW for a new one? I think it should only take a few minutes, as the symptoms are so bad. It's a 94 and has got the 6 pin connector (part no 021906461). I'm on holiday all this week, and need to try and get it sorted asap if I can. Thanks all in advance - Tim
You sure it's not the Lambda?
I've tried unplugging the MAF on mine a while ago 'out of interest' and found the engine hiccoughed a little when it was unplugged, but then continued to idle as normal.
You might get a better response if you ask a mod to move the topic to Engine Bay.
Reggit - don't think it's the lambda - that was replaced 5-6 weeks ago - when the lambda was knackered I was still averaging 25mpg!
I have one
Bigpants baby - is that one I can try or one I can buy? Only problem is I need to try one before buying a new one, and unless you're up here visiting a round trip of 500 miles is a bit too far - unless of course no one a bit more lcoal to me can help out!!!
You need to reset the ECU after changing the lambda. It will ignore the new lambda till you clear the error codes and it's a good idea to do it anyway when you change a major electronic sensor ..
Note that on late VRs unplugging the MAF at idle will not be noticed by the engine. But I note you have a '94 with the six-pin MAF, so I don't have direct experience of running one of those.. Mine is a '95 with coil pack and 4-pin MAF..
