TITAN 0 Posted January 28, 2008 My mates VW bug will not go into gear was driving fine no slipping or any fault with the gears parked up whent to move off will not go in to gears its a 55 plate no leak from brake cylinder i pumpped the pedal gets a little better could this be slave clinder fault ?? anyone come across this . Thank. Quote Share this post Link to post Share on other sites
TITAN 0 Posted January 29, 2008 JUST NOTE TO SA Y dealer can not fine why clutch not working so they are replacing clutch & fly wheel under warranty! :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 29, 2008 This will be the DMF breaking up - you can usually see it moving if you stick a screwdriver down the inspection hole... Quote Share this post Link to post Share on other sites
