boost monkey 0 Posted February 3, 2008 Hi guys, have got a few missing connectors on my Corrado (still with Russed16 at the mo) There's a brown 2-pin connector at gearbox end (fits on the WUR and on the cold start injector, but they have a white and blue connector respectively) Also a few random 1-pin jobbies floating round that end - green/red striped item and also a white/black(?) item too. Any pictures of the loom and connectors around the engine bay will be massively helpful. I will actually send you cash money. That's no lie. So, anyone who has an early 1.8 16v and a hi-qualitee camera, go crazy.... 8) 8) 8) Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 4, 2008 favourite Mr. Men Character? Mr. Bump. Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 4, 2008 Let me know the wire colours and I will check the wiring manual to see where it is all suppossed to go. The random 1 pin jobbies are probably for the additional instruments, these were built into all looms, so oil pressure and battery volts. Or look at the fan overrun thermal switch. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 4, 2008 Cool, cheers. There's a 2-pin brown square connector, exactly the same as the blue cold start injector, and the white WUR connector. Any ideas? Thanks for the 1-pin connectors, I won't worry about them for now then. what is the fan overrun thermal switch, i can only think of the 3-pin items connecting to the fan itself and also the temp switch in the bottom of the rad. Quote Share this post Link to post Share on other sites
steveo29 0 Posted February 4, 2008 brown one...does it fit on the thermotime switch? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 4, 2008 where is the thermotime switch? Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted February 4, 2008 what is the fan overrun thermal switch, i can only think of the 3-pin items connecting to the fan itself and also the temp switch in the bottom of the rad. Oh! makes sense... That was probably the loose single spade that came out of the fan loom! Why didn't I think of that? :( The fan overrun keeps the fan going after the engine is switched off, and I think is triggered by a sender in the block? Result is that the coolant in the rad gets fanned for longer if the engine is hot, so that you have cool coolant if you start up again soon after stopping. At least, that's my understanding, but as you know, I'm just a curious enthusiast - I'll leave the definitive statements for the experts with KR experience! :lol: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 4, 2008 Aha. Well both the KRs I've had had completely different single pin connectors on the sides, so i'm stumped! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 8, 2008 Surely someone is willing to go pop their bonnet and take a few pictures...? I'm going back up tomorrow.... anyone???? Anyone at all? :( Quote Share this post Link to post Share on other sites
White2505 0 Posted February 9, 2008 On the g/box end of the engine there are three single connectors. Placed around the outlet pipe. Looking at it, top left is Yellor/Red; bottom left is Green/Red; top right is Blue/White. The single one 'just round the corner on the back' of the engine is Green/Black and fits the sensor sticking out the back just there. (There are two earth wires connected to the top of the block just here as well, one is Brown/White and in the same sleeve as the sensor wire, other is Brown and comes down sleeve from the coil area). The oil cooler has two sensors, front one is Yellow; back one is Blue/Black. There is an unused wire tied back which is Blue/White. HTH Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 9, 2008 :shock: i deffo know the green/red isn't connected to anything, maybe that is what is tripping out the engine so much... Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 9, 2008 On the g/box end of the engine there are three single connectors. Placed around the outlet pipe. Looking at it, top left is Yellor/Red; bottom left is Green/Red; top right is Blue/White. The single one 'just round the corner on the back' of the engine is Green/Black and fits the sensor sticking out the back just there. (There are two earth wires connected to the top of the block just here as well, one is Brown/White and in the same sleeve as the sensor wire, other is Brown and comes down sleeve from the coil area). The oil cooler has two sensors, front one is Yellow; back one is Blue/Black. There is an unused wire tied back which is Blue/White. HTH helps massively thanks so much :D :D :D Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 9, 2008 White 2505, do you have a 2-pin brown connector that fits on the WUR and CSV but isn't actually connected to anything, or is it connected up to something i have missed? Quote Share this post Link to post Share on other sites
