wraggyG60
1991 g60 fuel filter
does anybody know where the fuel filter is on a 1991 G60?????
its not under the car so i can only assume its in the tank along with the fuel pump....
Welcome to the forum, it is under the car (same location as a MK3 Golf - Look under filler neck side rear wheel arch)
If it's not been off for a while you may find the metal bracket is rather rusty, easiest thing to do is to replace this with the later plastic carrier as fitted to MK3's etc, make sure you get new bolts / clips while your at it...
It is under the car..
Jack the back end up, stick some axle stands in and get under the drivers side just in front of the rear wheel. If you look up you will see a black plastic cage with a rubber fuel line going in one end and out the other - you will find it is held on by 2 x 15mm nuts.
