bomberbolton
squeeky belt, the plot thickens. . .
wonder if any of you guys can help me. . .
*changed the ancillary belt on my k-reg corrado vr6 (no air con)
about 50 miles later i started getting a skreech.
*then replaced the tensioner which was faulty (self tensioner)
still noisy
*took belt off and spun water pump which sounded a bit dodgy, replaced pump (fubar) and pully
also replaced belt again in case it was faulty
didnt make a noise for about a week but its squeeking again now
so basically its had
*belt (x2)
*tensioner
*water pump and pully
belt is tight and car is running fine other than noise
any ideas!!!?
Been here before on a G60 with a pattern parts belt making a total RACKET. The noise was terrible - some folks even suggested my G-Lader was about to die.
VW belts have some sort of cloth / stitching in them designed to eliminate this specifically. Changed over to a genuine VW one - noise went away and never came back!
hello everyone. . . thought i would start off with a question. . .
i got the belts from german and sweedish. . .
so maybe a trip to vw is in order, a guy said it couls be a kindof laquer on the belt itself, that takes a while to peel off, but thats pretty much eliminated now.
many thanks, will try this and see how it goes, will be nice to hear the engine for a change. ..
  Quote
I think we've found the problem!
Try a new genuine one and keep the other as a spare in the car...
