VAG-hag 0 Posted February 6, 2008 I really need some advise on clubsports. Ive just had them fitted to my C & the front is now pretty low to say the least. Does anyone know how to adjust the hieght on these? Any clues on the 'min' drop from these? I am very sure that they can be adjusted (ive just checked the blurb online now) but im a lil nervy that im not going to be able to go anywhere but tracks :( Any help will be greatly appreciated 8) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 6, 2008 Did they not come with any adjusters? You should have 2 brass coloured metal C spanners in a blue H&R bag. You use the two spanners together to unlock the two rings under the bottom spring, then use one spanner to turn the upper ring up the threads to raise the ride height! Quote Share this post Link to post Share on other sites
