weetos 0 Posted February 14, 2008 hi all whats the electrical plug that sits on top of the rear engine mount on a g60 for?? my c's just started missing on load. :( I changed the mounts last weekend could this be related? :? I'm changing leads dizzy cap, rotor arm and fuel filter tomorrow plugs are 1k old Quote Share this post Link to post Share on other sites
craigowl 0 Posted February 15, 2008 On the VR6, there is one and it is for the lambda sensor IIRC. Quote Share this post Link to post Share on other sites
weetos 0 Posted February 15, 2008 sounds like it could be that then as its only missing when warm ta lee Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 15, 2008 Yeah Lambda - the G60 also requires an earth thru this bracket so check that also! Quote Share this post Link to post Share on other sites
Yandards 0 Posted February 15, 2008 Yup lambda probe, bit wierd that it is not connected. You might find the car runs worse with it connected, if so get a new one fitted and you should find that it goes quicker than it ever has. Quote Share this post Link to post Share on other sites
weetos 0 Posted February 16, 2008 all sorted :D FYI ht leads were fecked Quote Share this post Link to post Share on other sites
