inky
Vr6 engine problems
Any help appreciated, car has been off road for 3 months and was started regularly.
Back on the road today and now having problems.....
Will not start first time (as before)
Cutting out at low speeds
Idling randomly (anywhere between 550 & 2000 rpm)
Any ideas
was running perfectly
any help please
oh and by the way this is not a raddo its a Vr6 p**srat (not mine but getting it back on the road means I get my raddo back of hubby)
What year? any fault codes?
Sounds like an air leak,cheack the isv damper pot.
hi 94 passat, no access to vag com, but will give your suggestion a go
thanks
All sorted - just had to reset the ECU - 10sec to fix!(had forgotten the battery had been disconnected briefly in November when it can off the road)
cheers for the responses anyway!
If only all Corrado problems were that easy to fix :lol:
its fixed my corrado problem.............I GET IT BACK!!!!! :D
