Patch
Wheel bearings
Right i've managed to find some spare hubs,i'm going to scrub them and paint then black.How do i get the old bearing out?
Safest thing to do is press them out and press new ones in again, brute force and ignorance can be used to remove the old bearings :norty: , you will find they seperate leaving half on the shaft, you can grind through it but be careful not to damage the stub. :shock: rear bearings are so much easier! You will have to remove the old hub and carrier from the suspension leg which will mean resetting the geometry [camber]. Good luck :) Can post up piccies if required but quality not good on mobile phone shots!
I might take them to a local garage and get them to press them out,i can get on with cleaning them up and repainting then.
