steve @ 0 Posted March 22, 2008 Hi guys Just fitted my 268's. All went well. On timing the new cams up the front(shorter) was spot on however the rear(longer) cam didnt quite line up i.e to get the 4mm sheet in. It required the crank turning ever so slightly and i mean slightly. Its not a tooth out as that would swing the cam to far the other way. Anyways its all back together and running fine. I remember seeing this on vw vortex just wonder if anyones come across this before. Quote Share this post Link to post Share on other sites
