andydoc1 0 Posted March 29, 2008 hI , GOT A 16V 1.8 1989 G , having real hassle selecting reverse , it will go in with a real shove but it makes the tarnsmission crash into gear , all other gears seem fine a touch notchy but i think they are like that any way, could it be oil ? could it be linkage ? could it be just a knackered box ? its done 120k miles can some one help as ive been quted £530 to replace it and i really dont think its the box , but im sure someone on here can help ? thanks :D Quote Share this post Link to post Share on other sites
joby 0 Posted March 29, 2008 There is a circlip that breaks, pull the gearstick housing off and you can see it! Do a search on here and you will find its happened to lots on here :) Quote Share this post Link to post Share on other sites
andydoc1 0 Posted March 29, 2008 ok thanks sorry to be thick but do you mean in under the gator in the car ? thanks Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 29, 2008 Yup, under the leather bit :D Quote Share this post Link to post Share on other sites
andydoc1 0 Posted March 29, 2008 mm the circlip is ok and all tite , any other idea pls guys ? :scratch: :? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 29, 2008 Does the stick push down ok? Quote Share this post Link to post Share on other sites
andydoc1 0 Posted March 29, 2008 yep it pushes down ok and all is tite in looks ok ? :( Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 29, 2008 Ok, have you had a look in the engine bay to see if anything is restricting movement - might just be dirt, a cable or broken clip stuck under the shift tower etc? Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 29, 2008 Try the search mate!1 This thread might help? http://www.the-corrado.net/.archive/forum/viewto ... no+reverse Quote Share this post Link to post Share on other sites
andydoc1 0 Posted March 29, 2008 ok thanks guys when the rain stops persisting down i will don me wellies and have a look , let you knw ta Quote Share this post Link to post Share on other sites
