Supercharged Junkie 0 Posted March 29, 2008 Hi, replacing some vacuum hoses on my G60 and just want to make sure i get the right size. I know the vacuum hose between the TB and ECU has to be 1m but what ID is it? 3 or 3.5mm also looking at EKTA, it states the vacuum hose between the inlet manifold and FPR has to be 100mm, but doesn`t say what ID? Thanks for any help Ian Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 29, 2008 Yeah ETKA assumes you buy that part which I am fairly sure is 3.2mm ID like most other VW vac pipes - this one has a white tracer. It's about £4 from any dealer and they should have a roll in stock, don't trust them to measure it tho! Also don't use silicon as it can collapse. Quote Share this post Link to post Share on other sites
Supercharged Junkie 0 Posted March 29, 2008 Also don't use silicon as it can collapse. Damn, that what i was going to replace them all with :( Oh well, cheers Supercharged Quote Share this post Link to post Share on other sites
weetos 0 Posted March 30, 2008 it's 3.5mm id m8 not 3.2 Quote Share this post Link to post Share on other sites
Supercharged Junkie 0 Posted March 31, 2008 Well, Went to replace the vacuum pipe from the inlet manifold to the fpr and found the cause of my sluggish performance i have been having recently There was a great big split in the rubber pipe i had on there replaced it with some VAG vacuum pipe and Wow its back to normal :) It must of been running well lean, feels so much more responsive now :clap: it's 3.5mm id m8 not 3.2 Yeah, i thought that! Quote Share this post Link to post Share on other sites
