aks650
vr6 starting??
Hi need some help,
when i start my vr6 corrado the engine has to turn over quite a bit before it fires up, when its started its running great! what could cause this? new plugs, leads anything else?!
Please help lol
i'm not sure how do you tell? just seems ti be turning over for a while and sometimes a liitle touch of throttle and it fires up
When you turn the ignition on the fuel pump should run for a few seconds then stop, this pressurises the fuel system. You should be able to hear it, a quiet whine noise, it may help if you take the rear parcel shelf out.
