M15 VW
superceded - vr6 oil pump gasket?
Rang the dealers today and they said the gaskets for the vr6 oil pump are not available anymore.
Is this true?
It is the gasket that goes from the oil pressure pipe to the oil pump housing. Also does anyone know what size the o rings are? finally, does anybody know if the oil pump comes as a complete unit with the cover and pressure relief valve?
Thanks
Yes pump comes complete.
There is no pump gasket for the 12V. The output tube bolts on plain at both ends.
If you want an O ring, you'll need to use the R32 output tube which has a captive O ring at the block end. Pump end is plain as per the 12V.
