sparks
the dash computer
hi guys
right i had a sicrroco scala before and the dash computer dont alot more than the rados one can anyone list the standard function of the G60 one
at the mo ive got mpg, oil temp,mile travelled ,time taken and average speed pulling the slide switch all the way to the left zeros it all
but pushing in the little button on the end does nothing not sure on weather got a dicky switch or the computer doesnt do have the stuff the scirroco did ??
cheers
stu ....
You mean the MFA?
You should have:
Time Travelled
Average MPG
Average Speed
Distance Travelled
Ambient (outside) Temp
Oil Temp
You should have a number 1 & number 2 setting on the stalk
Number 1 is readings from your current journey.
Number 2 is overall readings since you last reset
Reset number 1 by sliding and holding switch to the left
Reset number 2 by sliding and holding the switch to the right
If the display doesn't change when you press the button on the end in, it sounds like maybe a dodgy stalk
I'm sure I've read on here that you can check boost pressure and other charger related stuff using the MFA on the G60's, wouldn't know for sure though as I've got the VR6...
Someone may be along shortly to set that straight.
Hope this helps chap! :D
Hi - another quick question about MFA - how do i swap between trip 1 and trip 2 details?
mine just cycles in either trip 1 or 2 and i dont know how to swap...
cheers,
joe
:D flick the switch between the 2 depending on which one you want to cycle through.
