markieshero
ABS LIGHT ON DASH
My ABS light is burning on the dash, however everything all the brakes would appear to be working grand!
Is there anything simple I can check to eliminate this problem (other thatn take the bulb out!) :shock:
There doesn't appear to be any obstructions on the abs sensors as normally some dirt or rust on the sensor.? any suggestions????? The dash light only comes on once the car moves?
Are sensors expensive?
:help: :help:
*points to search button*
there's plenty of info on pretty much all apesct of the ABS system matey, sensors, cages, wiring, main unit etc etc.
