Thom
Alloy Wheel Fitting
Hi, have bought a set of TSW Hockenhiems on ebay, they came from a Vauxhall Cavalier which shares the 4x100pcd with the VWs, however, the inside centre diameter is about 2mm less than it has to be to fit the car. Checking the model online shows that it should fit a corrado, is there any harm in filing this doen very slightly to get it on?
i would not file it you need this to be accurate otherwise you might get wheel wobble because you have a certain amount of play in wheel studs and the holes in the wheels are not diameter exact so the spigots hold the wheel in place
but its upto you .
just a thought most after market wheels inc tsw s have removable spiggots but they are plastic some are alluminium so you would have noticed :scratch:
The centre diameter you refer to is known as the centre bore.
Most aftermarket wheels have a very large centre bore which can be reduced by fitting the correct size spigot rings.
If your wheels have spigot rings fitted then you need to source the correct size rings for your vehicle.
If there are no spigot rings fitted and the centre bore is too small to fit your car then the wheels you have are never going to fit your car.
if there are no removable spiggot rings you could get them machined out the measurement is 57.1mm centre bore
