ianmorgan50
HEEP NEEDED CORRADO G60
MY HEAD GASKET HASJUST BLOWN ON MY G60 AND NEED SOME ADVICE ON DOING IT ANY TIPS ANY1 CAN GIVE ME WOULD BE GREAT ALSO IF ANY1'S IN BRISTOL AND WONTS 2 LEAN A HAND THAT WOULD BE GOOD 2
Friend i'd loose the capitals,people tend to take it as shouting on line..
Sorry to hear about your car.
Good haynes manual will do the trick for general procedure for removing/installing an 8valve VW head.
There is also plenty of info on this site for draining coolant system setting up your timing after etc..
Do a search and then if you have any specific questions then come back.
Good luck.
ok thanks for that i use lower case from noe on lol
im thinking since it off the road to do some big mods
im thinking as flollows:
4 branch manifold
p&p head
samco hoses
charge cooler
and eather a stage 4 supercharger and rebuild or a bbm screw charger but if i do this do i still need a cool charger
also with thease mods do i need to the piston or conrods or any thing else
No need for any bottom end work mate.
Charge cooling is always a good idea with boost.So a fmic or a charge cooler would be good to get the most out of any mods.
