jacko
VagCom Help
I ve had a few problems with my new raddo over the last week. I plugged my vagcom into it and these are the results... the only problem is it all means nothing to me ha
any help or info would be great!
Chassis Type: 50 - VW Corrado
Scan: 01,02,03,08,15,25
Address 01: Engine
Controller: 021 906 258 AG
Component: MOTOR PMC 1
Coding: 0261203109
Shop #: 1267357531
4 Faults Found:
00533 - Idle Speed Regulation
10-00 - Adaptation Limit Not Reached
00525 - Shareware Version. To Decode all DTCs
03-10 - Please Register/Activate - Intermittent
00537 - Shareware Version. To Decode all DTCs
11-10 - Please Register/Activate - Intermittent
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
Readiness: N/A
Address 03: ABS Brakes
Controller: ABS /ED S
Note: Excessive Comm Errors
i just realised there is a vag-com thread on the fourm. Just looked at the pictures of the port next to the gear shift... i have a 16 pin ODB2 port on a 1994 early type raddo vr6. is this normal or has my car been buggered about with at some point in its life. The reason why im looking at my vagcom is beacuse the other day when i was crusing at 40mph and i lost all power for about 20 seconds. i was stamping on the throttle and nothing was happening. My friend was was in the car at the time noticed the ABS light was on while i had no power. I also, in all the rain we had this week gained a rather large puddle in the passenger footwell and in the rear. Not sure if its from a random hole in the body some wehre or a knackered heater matrix but there was alot of water there. I have also read soem where that the ABS ECU is in the passenger footwell on the side, im starting to wonder if this has been affected by the mass of water. Yesterday the ABS light came on again, i thought it could of been a sensor i cracked while replacing the suspension, that has now been replaced but the light is still on. Please can some one tell me whats going on as im quite worried. thanks
Reset the faults, then see which ones come back. Also, don't even bother scanning for faults if the engine is stopped, you'll just keep seeing "engine speed sensor: no signal" otherwise.
As for total loss of power .. would suggest you start looking at the ignition switch and ECU relays ..
ok thanks. i will get them reset and see whats happening then. I have an idle problem any way so im trying to find the case of that. some times its hangs about 800 rpm or sometimes at 1000.
