cheesey
picture question
is this ment to be conected to anything
as its just dangling
all i know is its something to do with the boost
could this be the cause of the noise on accelaration
oh yeah just tried to replace the passenger side door handle
with a passat rear 1 it dont work what else do you have to do
Isn't it the boost return valve? If it is there should be a linkage that connects to the throttle valve. Means that it's stuck open, probably makes a whistling sort of noise and that you're not getting full boost a WOT.
PS If it's the linkage you need I may have one
